×I have two different jira instances in the same organization and I see that this instance has different UX experiences.
For example, one of them has the ability to add a column on the issue grid, and the second does not.
How can I check if the UX version is "newer" and how can I enable the exact same UX for both instances?
There are many other minor differences and it's quite annoying.
Hi @k.kawalec
Share the screenshots. You must be looking at different type of projects in Jira.
Ravi
Jira 1: Missing icon for selecting column (on full page width result is the same)
Jira 2:
Jira 1: Top left view, item details from filter list "all issues"
Jira 2: Top left view, item details from filter list "all issues"
That might be a dumb suggestion, but have you tried to scroll right in your first Jira 1 screenshot and then you'll see the column selection?
