I'm looking at the various tools for syncing two jira instances.
The problem is that the github admin and the jira admin are completely separated.
The idea is to use a shared jira instance where admin credentials can be shared so that the github admin can setup the github integration on that instance and the jira admin can then sync everything back and forth from the main jira instance.
Jira Instance <----> Jira Bridge Instance <---> github.
We are not looking for syncing of github issues but all manner of other info such as pull requests and such.
Thanks!
Hi @Larry
This is Dhiren from Exalate.
Exalate, provides a fully bi-directional synchronization between GitHub and Jira (among other ITSM systems) that is fully customizable. It is easy to set up and Exalate uses a scripting engine which is based on Groovy scripts where you can control what data you want to share and even you can independently handle the incoming information. You can achieve complex use-cases with ease.
You can easily fetch data from GitHub repositories and sync issues from GitHub to issues in Jira.
If you would like to see a customized demo of the product in action, feel free to book a slot with us.
Dhiren
@Dhiren Notani_Exalate_ Please review our guidelines for Marketplace and Solution Partners , specifically:
Please disclose your association to the marketplace app you've linked and update your profile !
@Larry hi there! Diana from ZigiWave here. Take a look at ZigiOps. It's a no-code tool that can help you set a bi-directional connection between the two Jira instances and the GitHub one. You can customize the tool in order to fit various use cases. ZigiOps can help sync issues, pull requests, commits, branches, etc. Feel free to take a look at it and if you want to see it in action, you can book a demo.
BR, Diana
Hi @Larry
I'm not sure if I understood your use case correctly, so I'll ask again.
Is your only reason to introduce the synchronization so that the github admin can setup the integration between github and Jira correctly?
If so, wouldn't it be an option that the two admins sit together (virtually) and complete the setup without setting up an additional instance? I haven't used the github integration but I believe this is also more a one-time setup you'd need to do - and nothing you always need permissions for (Correct me if I'm wrong).
Matthias.
