Unable to Create an issue in JIRA
Kalese Webber
We are currently unable to create issues in JIRA or by using the JIRA plug-in in our ticketing system (Zendesk).
We are unable to create issues in any of our main workspaces (SIU, PARTS, WAF). When attempting to create an issue, the user is prompted to fill out fields that don't actually apply and don't even appear in the list of fields.
Is there a workaround for this issue?
Thanks!
Eduard M
November 23, 2017
Hello Kalese,
This is not a commonly occurring problem and from the information given it's not enough to know what is going wrong. You may want to look in the atlassian-jira.log for errors and use the safe mode to run without add-ons:
You can enable JIRA safe mode through the UI as an administrator. You will navigate to Manage Add-ons when logged in as an administrator. Click Enable safe mode at the bottom of the page.
This is described in: https://confluence.atlassian.com/jirakb/add-on-tips-and-tricks-779168621.html
If that helps it's likely that an add-on is preventing the correct functionality.
Kalese Webber
Thanks Eduard!
We actually found that the Capture for JIRA field was set to required but was not visible in the screen when making the JIRA. Somehow it switched because we did not manually change it. So we switched it back to optional and it worked.
Turns out it was not the plug in causing the issue; it was an issue in JIRA.
Eduard M
November 27, 2017
Hi Kalese, that's great that you were able to locate the setting and fix it this way. Good luck further!
Martin Orzaiz (Atlassian)
November 23, 2017
Hey Kalese,
Things to be tried:
  1. Before anything, perform a full re-index through Administration > Indexing > Re-index and see if this takes care of the issue.
  2. If not, run the Database Integrity Checker and see if that comes up with issues to fix. Try again.
  3. If that does not work also, go to Administration > Plugins and Enable Plugin Safe Mode. If this solves things, go out of plugin safe mode without restoring previous configuration and then enable plugins one-by-one to see which one causes the problem.
  4. Please check the screens and workflows just in case to see that you have the ability to create issues. If you have a required field and it's not in the screen, you should go and add it, otherwise you won't be able to create a ticket correctly.
  5. Were there any changes made prior to the issue occurring?
Thanks in advance.
Martin
Kalese Webber
Thanks Martin!
