does anyone know why I'm getting this issue? did I make any mistake while creating a project? is there any solution to fix this issue?
Hi @vdhanorkar ,
Please find the below solution
Any other user able to access that page ..?
Please accept the answer If it helps you 😊.
Sanjen
Hi @vdhanorkar ,
Could you please check the base URL..? Is the base url correct or not..?
If still facing the same issue, Kindly connect with Atlassian team to resolve it .
Raise atlassian support ticket
Sanjen
Don't forgot to hit the answer button If it helps you.
Hi @vdhanorkar ,
If still facing the same issue, Kindly raise a support ticket to Atlassian team.
Sanjen
Accept the answer If it helps you.
