Unable to move a issue from one project to another.
Pavan April 8, 2024
I am unable to move a issue from one project to another,
Ive checked Reporter, Assignee have all the permissions ( create, edit, move, assignable user, reporter) in both Source and Destination project.
Ive created a test ticket, assigned it to myself  able to move to the same project but failing to move another
Also attaching error screenshot for reference.
Pavan Kalyan.P
Matt Parks
April 8, 2024
Does the issue's current status exist in the workflow that  you will be moving it to? If not, it may be necessary to have the Transition Issues permission (I'm not sure, but it might be something to check).
Kalyan Sattaluri
April 8, 2024
Hello @Pavan
There are no screen shots. Please share.
Also, do *you* have permissions to create issues in Destination project?
Pavan April 8, 2024
Hey Kalyan,
Sry I missed it, here is the screenshot and also got the permissions to create, edit, move issues in destination project!Screenshot 2024-04-09 at 12.08.31 AM.png
