I added the "Comment" field as required using validator for a transition in a particular workflow in one of my JIRA Company managed software projects.
When I try to transition an issue, I get the "Transition Failed" error notification even after adding a comment to the particular issue.
I am guessing I have to figure out a way to add text to comment field while transitioning the issue. How do I accomplish this? Am I moving in the right direction?
Thanks!
When editing the workflow click on the transition and click edit
Then on the next pop-up in the 'screen' drop down choose comment screen
Do this will make the comment screen appear during the transition
Not sure if it will work buy try - 'Add Transition Screen' and add the Comment screen.
This will make it pop up while transition is taking place
I am fairly new to JIRA. How do I create a screen which will prompt me to add comments? Thank you!
This worked. I created a transition screen and added it to my transition. :)
See my reply above - forgot to put it in the reply section
