Unstoppable doesn't work
Edimara Souza
Hi everybody
I am using the Jira Software server v8.5.8#805008 and I install a Unstoppable plugin, and create a group fot them and add an user, but even thogh I can't hear anything
There is another configuration for unstoppable?
At documentation I didn't understand this part:
  • Once installed, You will need to create accessibility group and add it to unstoppable in the configuration screen."
 https://www.addteq.com/products/unstoppable/help/installation-guide-for-jira
Can anyone help me?
Robert Horan
Hi @Edimara Souza
Please try contacting the support team: https://www.addteq.com/products/unstoppable/support
This will ensure your request is routed appropriately and addressed as soon as possible.  Thanks!
Shardul Juyal {Addteq}
Thanks @Robert Horan
Hi @Edimara Souza , can you please let me know which screenreader you are using?
Like Robert Horan likes this
Deepanshu Natani
Hi @Edimara Souza
After creating the group, have you added that group in the "unstoppable" plugin's configuration?
