Update custom field using jira-python
thekngmkr2015 July 19, 2017
issue.update(fields={'customfield_10100': {'value','Two'}})
I have a multiselect list and below error occurs if i try to update
"response text = {"errorMessages":[],"errors":{"Custom_field":"data was not an array"}}"
3 votes
Shaun S
July 29, 2017
Hi Amar,
I was able to set the field values for a multi-select field by correcting the syntax of the code you provided.  I used the REST API Example as a guide.  If you change the code to read as
issue.update(fields={'customfield_10100': [{'value':'Two'}]})
I believe it should work.
thekngmkr2015 July 30, 2017
yes thank you for the reply.. i did figured it out
deepak.rohilla September 19, 2022
Hey i need to modify single select field (drop down)  i tried below code.
1. issue.update(fields={'customfield_11104': 'Staging'})
2. issue.update(fields={'customfield_11104': [{'value': 'Staging'}]})
3. I tried this one also issue.update(fields={'customfield_11104':[{'value':'46707'}]})
but got the error like
response text = {"errorMessages":[],"errors":{"customfield_11104":"Could not find valid 'id' or 'value' in the Parent Option object."}}
Like Carlos Catrilef likes this
This customfield_11104 is a single select dorp down field.
Helen Black
March 29, 2023
The metadata for my single select dropdown field includes "set", "value" and "id" and I found that only  "id" worked as follows:
 issue.update(fields={'customfield_11104': {'id':'10034'}})
I found the "id" for my field as follows:
jira = JIRA(jira_server, basic_auth=(jira_user, jira_token))
meta = jira.editmeta('ABC-1')
print(meta)
