I went to move a board to trash and it moved my project to trash in JIRA. Trying to recover project. Do you know how I can do this.
It said I had 60 days until it was permanently deleted - any way to find trash and restore project? I'm a site admin.
Amitha
Under JIRA settings > Projects > Trash
If you use the top navbar to get to Projects > View all projects, this view doesn't have the Trashed projects view within it.
Instead you need to go to the the Cog Icon (Setitngs) in the top right corner as a Jira Admin and select Projects, this will take you to the page to be able to see this. The URL will look like this [yoursite].atlassian.net/jira/settings/projects/trash
If you're not a Jira Admin, you won't be able to view or manage trashed projects.
you can do that if you have a backup. If you do not have a backup, then you're lost.
