Using Issue collector in React
BRUCE HAMMOND
January 3, 2022
I can get Jira issue collector to work in a Confluence page, but not in React.  Can you tell me how to do it in React?
Andy Heinzer
January 5, 2022
Hi Bruce,
I understand that you are building a react app and are wanting to include a Jira Issue collector within it.  While I have not done this myself, I found another thread here is Community that appears to have a solution.  Check out https://community.atlassian.com/t5/Jira-questions/Jira-issue-collector-for-react-app/qaq-p/1411911
That thread appears to contain a couple of different approaches to getting this to work.
I hope that helps.
Andy
BRUCE HAMMOND
January 5, 2022
That solution pops up the issue collector on a new window and I want it to pop-up on the current window because the new window doesn't close when the issue is submitted.  I found a solution that does though as below.
import React from 'react';
import jQuery from 'jquery';
import {Row, Col, Button} from 'reactstrap'
const ELEMENT_ID = 'jira-feedback-button';
const WINDOW_VAR_NAME = 'jiraIssueCollector';
window['ATL_JQ_PAGE_PROPS'] = {
"triggerFunction": function(showCollectorDialog) {
jQuery(`#${ELEMENT_ID}`).click(function(e) {
console.log('triggerFunction')
e.preventDefault();
showCollectorDialog();
const JIRAIssueCollector = () => {
const setCollector = () => {
const appElement = document.querySelector('body');
if (appElement) {
console.log('loading issue collector');
const snippet = document.createElement('script');
snippet.type = 'text/javascript';
snippet.src = "YOUR ISSUE COLLECTOR URL";
appElement.appendChild(snippet);
if (!window[WINDOW_VAR_NAME]) {
setCollector();
window[WINDOW_VAR_NAME] = this;
return (
<Row>
<Col>
<Button href="#" color="primary" id={ELEMENT_ID}>
Provide Feedback
</Button>
</Col>
</Row>
export default JIRAIssueCollector;
Like # people like this
Marc
April 15, 2022
Thks Bruce it's working like a charm for me.
Meddy Lebrun
August 24, 2022
Without using Jquery in a React environment :
document.getElementById(ELEMENT_ID).addEventListener('click', function (e) {
e.preventDefault();
