Using Jira with MS Teams
Simon Huprich
I noticed that it isn´t possible any more to use the JIRA Cloud App (by Atlassian) as integration in MS Teams. The ratings are also really bad at the moment.
Is there a reason?
Or is there another (free) way?
Greetings
Simon
Pramodh M
Hi @Simon Huprich
The App is not compatible with Cloud for one which is created by Atlassian!!
For DC Version, there is no control over notifications.
You need to choose the other marketplace plugins in order to have better integration with MS Teams.
Pramodh
Simon Huprich
Thank you
Like Pramodh M likes this
Tony Knopp
January 19, 2022
Hey @Simon Huprich
I'm the engineering manager for the Product Integrations team at Atlassian and I wanted to let you know there is a free and functional MS Teams <> Jira Cloud integration available.
You should be able to install the Teams app from here
https://appsource.microsoft.com/en-us/product/office/WA200002140?tab=Overview
Or by finding the "Jira Cloud" app in the App store within Teams.
It was built with Jira Software in mind but can be used with JWM as well.
Feel free to respond here if you're having any trouble getting things installed/signed in and I can assist!
cc: @Tygrr DosRemedios
Simon Huprich
Thank you!
