Using REST API to edit issue - CURL succeeds, programmatically fails
Janene Pappas
September 17, 2020
I'm trying to use the Jira REST API to update issues programmatically via a MacOS program, written in Swift. I have a Jira API Token and have succeeded using CURL. Here is the command:
curl --request PUT \
  --url 'https://xxxx.atlassian.net/rest/api/2/issue/SAN-2' \
  --user 'xxx@yyy.com:zzz' \
  --header 'Accept: application/json' \
  --header 'Content-Type: application/json' \
  --data '{
"update": {
"timetracking": [
"edit": {
"originalEstimate": "1w 1d"
Where zzz is the API Token. This works and the field is updated correctly.
The code version mirrors this as closely as I can, but fails with the error
Response: {"errorMessages":["Issue does not exist or you do not have permission to see it."],"errors":{}}
Here is the Swift code:
        let tokenString = "xxx@yyy.com:zzz"
        guard let encodedTokenString = tokenString.data(using: .utf8)?.base64EncodedData() else { fatalError("Can't encode token") }
        let authString = String("Token token=\(encodedTokenString)")
        guard let url = URL(string: "https://xxxx.atlassian.net/rest/api/2/issue/SAN-2")
        else {
            fatalError("Couldn't create a static URL")
        let request = NSMutableURLRequest(url: url)
        request.addValue(authString, forHTTPHeaderField: "Authorization")
        request.addValue("application/json", forHTTPHeaderField: "Content-Type")
        request.httpMethod = "PUT"
        let dataString = "{\"update\": {\"timetracking\": [{\"edit\": {\"originalEstimate\": \"1w 1d\"}}]}}".utf8
        let body = Data(dataString)
        request.httpBody = body
        let session = URLSession.shared
        session.dataTask(with: request as URLRequest) { (data, response, error) -> Void in
            guard let data = data, let responseString = NSString(data: data, encoding: String.Encoding.utf8.rawValue) as String?, !responseString.isEmpty else {
                print("No valid response!")
                return
            print("Response: " + responseString)
}.resume()
What am I missing?
DPKJ
@Janene Pappas I'm not a Swift expert but your 'authString' have some issues.
This should be (in my opinion)
let authString = String("Basic \(encodedTokenString)")
Janene Pappas
September 18, 2020
ahhhh thank you!
