Hi, I´m trying to set up a post function script where the Enddate will be set to the end of the current month.
The actual script considers the currentdate value +30days.
Has anyone got an idea to change the +30 to endOfMonth?
import java.sql.Date
import java.sql.Timestamp
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import org.apache.log4j.Logger
import org.apache.log4j.Level
// Manager
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
//Values
CustomField currentDate = customFieldManager.getCustomFieldObject("customfield_11808")
Timestamp currentDateValue = (Timestamp)issue.getCustomFieldValue(currentDate)
Date newDateValue = new Date(currentDateValue.getTime())
//Add 1 month
newDateValue.setMonth(currentDateValue.getMonth() +1)
//Update custom field
issue.setCustomFieldValue(currentDate, newDateValue.toTimestamp())
Hello @Jörg Friedmann,
You can use the following code to get end of the month. Just modify to parameters according to your currentDateValue variable.
GregorianCalendar calendar = new GregorianCalendar(2018, 8, 0);
Date date = calendar.getTime();
DateFormat dateFormat = new SimpleDateFormat("yyyy-MM-dd");
// dateFormat.format(date) returns the last day of the month
Hi Thanks a lot but I´m running on an error
Can ypu please explain what you mean with currentDateValue vaiable?
I changed the date format to dd-MM-yy also but without success
If you want to set all dates to the current month's last day, you don't need use currentDateValue. I missunderstood, forget what I said:)
By the way did you import the date libraries?
I guess not.
I tried some modifcations but failed, Im not able to adapt your code to mine.
ALso what I do not understand is how your code interacts with the condition to set the new date of the issue to 1month in future.
Maybe my explanation was bad. Background is I have a workflow where every issue set to done will be cloned to a new issue. This new issue shall have the end date value changed 1month forward automatically.
