I am currently using Scriptrunner and I would like to find out how to make a group required on a workflow transition if a field is set to a value.
I have not used scriptrunner to do custom scripting.
Hi @Mohammed Khadir , what do you mean by "group required"? Is it about "group custom field"? Can you explain your use case better?
Sure, in a workflow transition, I have 3 AD groups set, I would like to make one or more required if a field is set to a certain value.
Hi @Mohammed Khadir where are these groups set? In Custom field?
Can you share screen or something what will explain it better?
