Using a drive letter in cluster.properties
IT Service Desk December 5, 2022
Is it possible to use a drive letter to refer to the shared home location in de cluster.properties file?
Now we use this line:
jira.shared.home = //hostname.of.netwerkdrive/folder1/Jira/Shared
The path is already mapped as drive letter J to the Windows server.
Is there a possibility to use that drive letter in de cluster.properties file?
Like: jira.shared.home = J:\
I tried that, but Jira doesn't start on this node anymore then.
Anyone has ideas? Thanks!
Charlie Misonne
I'm not 100% sure but I think you need to use forward slashes. Give it a try.
IT Service Desk December 6, 2022
I put the forward slash and he did translate it correct. However this is what happens:
2022-12-06 14:23:30,381+0100 JIRA-Bootstrap ERROR [c.a.jira.health.HealthChecks] Ensure JIRA has permission to create and write to the jira.home directory J:\.
Review our documentation for more information on setting your JIRA home.
2022-12-06 14:23:30,390+0100 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running Jira startup checks.
2022-12-06 14:23:30,390+0100 JIRA-Bootstrap FATAL [c.a.jira.startup.JiraStartupLogger] Startup check failed. Jira will be locked.
2022-12-06 14:23:30,486+0100 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Startup is complete. Jira is ready to serve.
If I use //hostname.of.netwerkdrive... which points to the same point, Jira starts up with no error.
What am I missing here?
Charlie Misonne
It's weird because it in the log entry it is still a backslash:
I can't really find anything about this in Atlassian documentation. Perhaps you can contact Atlassian support for this https://support.atlassian.com/contact/#/
In the custer.properties file I've put a slash forward ;-)
I've made a support ticket! Thanks for the quick reponses.
Zoran Atanasov
December 9, 2022
Hi @IT Service Desk
I have the same problem with mapping the shared folder to a mounted drive from NFS.
Did You get any answers from the support team?
Best Regards,
Zoran
Tony Escamilla April 30, 2024
Did you ever receive confirmation of what it should look like.  We are experiencing the same issue.
Aeris Iu
July 15, 2024
Hi guys,
Having the same issue here, any updates from Support?
Need guidance, thanks!
