Using conditional loop in calculated field JWT
simarpreet singh
Hi team,
I have created a number calculated field by JWT. Under math expression, I want to add a condition that when the option is yes for field A, this calculated field is set to 1, if the option is No, then this is set to 0. Else, nothing should happen.
I'm able to do this for yes and No. But not able to restrict it for other dropdown option which is None. I know I can remove None by making field A as mandatory and setting a default option, but I don't want to make that change.
Is there anyway to achieve this.
Simar
Thorsten Letschert _Decadis AG_
Hi @simarpreet singh ,
given your field A with the field code 12345, your expression could look like this:
%{12345} = "yes" ? 1 : (%{12345} = "no" ? 0 : null)
Please let me know if that solves your requirement.
Cheers
Thorsten
simarpreet singh
Hi @Thorsten Letschert _Decadis AG_ -
Unfortunately, this doesn't worked. It only works as
%{12345} = "yes" ? 1 : 0
 I cannot proceed further after 0 as the syntax doesn't permits. Indirectly, I can use if else but can't use if, else if, else... which you provided your solution on.
please specify 'I cannot proceed further' since everything is working as expected on my instance given the expression above, e.g.
simarpreet singh
Hey @Thorsten Letschert _Decadis AG_ -
It's working perpectly. Sorry I missed a bracket so was getting syntax error.
Thanks a to man... cheers
simarpreet singh
@Thorsten Letschert _Decadis AG_ - Can you also let me know which scripting language is this?
