Hello Team
I would like to display in structure under folder (Task not linked to user story) , all issues (task) that are not related to a user story using the link .
Could you help me please ?
Thank you
Regards
Try the below JQl in your structure. It worked for me.
project = RND and issuetype =Task and issueFunction not in linkedIssuesOf("project = RND")
Hello @Aditya Sastry
To use issueFunction we have to install script runner addon ;)
Thank you
Regards
On a lighter note, you should get it then 😉.
I have few questions to think of a custom solution -
1. Do you use the linked issues to link to stories?
2. Is it being done at any particular step?
3. Do the users use the more button to go to linked issues or do you have the option in the screen?
Thanks!
Hello @Aditya Sastry thank you for your reponse
But there are no solution except using another custom field to filfil the story id , so i use it
Regards
Thank you
@karim.belhadj Yes I know. Hence I asked you those set of questions to suggest. Good that you have already done it though..
