Using webService with created variables (smartvalues)
david_levy
I'm trying to send webRequest to API with smartvalue variable (OrgID and GroupID below) and it seems that the smartvalue are not injected into the Jspn body.
Tested when I explicitly placed those values and it works so the only issue is with passing the variable into the Body.
Will appreciate your help, thanks
Kalyan Sattaluri
March 7, 2024
Hello @david_levy
I would think those variables should resolve. Can you, Before Sending web request, Please add a "log action"  step and log your payload like below and share your audit log.
david_levy
Thanks, Kalyan,
With the add log, I was able to find a problem in my variable (typo), once fixed the regular text messages crossed.
FREE
