I wrote a code which copy from parent custom field- Select choice- the value, into the child issue custom field.
The code works pretty well, We can see the current value that copued into the chile custom field-Select choice (Pic 1)
We noticed that when we select 'Edit' screen, the value is "None", and when we came back to the issue screen, we saw the good value again. (Pic 2)
Please, I need your help, it's a little bit urgent..
My Code to aspecific issue:
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.util.ImportUtils;
import com.atlassian.jira.user.util.UserManager;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.issue.ModifiedValue;
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder;
import com.atlassian.jira.issue.util.IssueChangeHolder;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.security.groups.GroupManager;
import com.atlassian.jira.issue.IssueImpl;
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.event.type.EventDispatchOption;
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.customfields.option.Option
import com.atlassian.jira.issue.customfields.option.OptionsImpl
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
//Test
//def issueManager = ComponentAccessor.getIssueManager();
IssueManager issueManager = ComponentAccessor.getIssueManager();
def optionsManager = ComponentAccessor.getComponentOfType(OptionsManager.class);
//IssueManager issueManager = ComponentAccessor.getOSGiComponentInstanceOfType(IssueManager.class);
Issue issue = issueManager.getIssueObject("WBL-46292");
def customFieldManager = ComponentAccessor.getCustomFieldManager();
//def issue = event.issue as MutableIssue
//Copy WBL Agile Team value to Development Team field
if (issue.getIssueType().name=='QVR') {
log.warn 1;
//Get Assigned QA Team value and WBL Agile Team value
def QAteam = issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Assigned QA Team"));
def WBLteam = issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("WBL Agile Team"));
//Get WBL Agile Team value and development value
CustomField wbl = customFieldManager.getCustomFieldObjectByName("WBL Agile Team");
CustomField development = customFieldManager.getCustomFieldObjectByName("Development Team");
//Get value= 'Unassigned Team'
def value = ComponentAccessor.optionsManager.getAllOptions()?.find { it.getValue() == 'Unassigned Team' };
def cFieldValue = issue.getCustomFieldValue(wbl);
//Cope WBL Agile Team value to Development Team
IssueChangeHolder changeHolder1 = new DefaultIssueChangeHolder();
development.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(development), WBLteam), changeHolder1);
//If Assigned QA Team = null, Put 'Unassigned Team' in WBL Agile Team
if (!QAteam) {
def wblValue = ComponentAccessor.customFieldManager.getCustomFieldObjectByName("WBL Agile Team")
def cfConfig = wblValue.getRelevantConfig(issue)
def value2 = ComponentAccessor.optionsManager.getOptions(cfConfig)?.find {
it.toString() == value
issue.setCustomFieldValue(wblValue, [value]);
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
ComponentAccessor.getIssueManager().updateIssue(user, issue, EventDispatchOption.ISSUE_UPDATED, false);
log.warn 2;
//If Assigned QA Team != null, Put Assigned QA Team value in 'WBL Agile Team'
else {
log.warn 3;
it.toString() == QAteam
issue.setCustomFieldValue(wblValue, [QAteam]);
// apply changes to Jira -----------------------
def cFieldValue2 = issue.getCustomFieldValue(wbl);
log.warn cFieldValue2.toString();
log.warn QAteam;
def issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService);
boolean wasIndexing = ImportUtils.isIndexIssues();
ImportUtils.setIndexIssues(true);
log.warn("Reindex issue ${issue.key} ${issue.id}");
issueIndexingService.reIndex(issueManager.getIssueObject(issue.id));
ImportUtils.setIndexIssues(wasIndexing);
Hello @Dan27
This is uncommon behavior, may be some problem with indexing.
Try to use issue.setCustomFieldValue() instead of updateValue()
// set field values -------------------------------
issue.setCustomFieldValue(singleline_field, "test 1")
Also check this article about update fields in jira:
Depens on what you need.
Current user you can get like this
last question, The code didn't recognize the line:
Can you send me the imports ?
I think, you only missing
May be there are some behaviours on that field? That make empty it.
