in Reflect, there is an option to specify "Secret" for a password, for example, to hide sensitive data I have in a test case. Using what variable can I add this to a step in the test case? For example: insert a password (variable) in the password field. This entry for example ${sec(password)} does not work for me.
Hi @Adéla Hubená , welcome to the Atlassian Community and thanks for your post.
Is Reflect a testing app / plugin? I don't see anything with that name in the marketplace. Please can you confirm what your setup is so we can help?
Cheers
Hi @Valerie Knapp, thank you for your reply!
I use Zephyr Scale and run tests using Automate Test, which redirects me to the Reflect page. On this page is a "Secret" function where I can enter anything I want to keep hidden in the steps of a test case in Zephyr Scale for example, but to make it work and test it via "Automate Test" I need to know the variable :)
Hi @Adéla Hubená , thanks for your feedback and apologies for the delay in my responding here.
I still, unfortunately, don't really understand your configuration so I don't know how to help.
Have you reached out to the support of the vendor for Zephyr - https://marketplace.atlassian.com/apps/1213259/zephyr-test-management-and-automation-for-jira?hosting=cloud&tab=support .
Best wishes
