We are using Jira Software without a roadmaps and we want to create an initiative above epic and another level between epic and story. How we can create this?
Thank you
Welcome to the community !!
You can issue links to create your own hierarchy.
But to visualize the hierarchy and track the progress at each hierarchy level, you will need an app.
We have create an app just for this need, Agile Tools.
Agile Tools - Epic Tree, Links Tree and Time in Status
Key features of Links Hierarchy:
You get multiple other features as below in the same app
Welcome to the Community!
You will need an app to provide a layer above Epics - Advanced Roadmaps is the Atlassian one, but there are others in the marketplace.
Jira doesn't have a configurable hierarchy, you can't insert layers, it is fixed as Epic -> Issue -> Sub-task.
But the Structure app is a good way to make issues look like they have more layers.
Hi thanks for the answer!
Another question on the same topic - is it possible to change and create a story below the story in the hierarchy?
epic -> business story -> technical story -> sub task
like that?
Not with plain Jira. as I said earlier. You'll need to be looking at Structure for that.
@Rahul_RVS & @Tal Ben Avram: First, let me add my "welcome" to @Nic Brough -Adaptavist-'s
If it helps, you can learn more about Structure for Jira on the Atlassian Marketplace.
Let me know if you have any questions.
-dave
