We move issues between projects. Is there a query to find all the keys an issue might have had in its lifetime?
Sean deBardelaben
Is it possible to find all the issuekeys an issue might have had in its lifetime?
4 votes
Cyril Egan
August 19, 2013
Install the Script Runner Plugin.
Create a scripted custom field e.g. "Previous Jira Key/s"
Add the following script to the field:
import com.atlassian.jira.ComponentManager
def componentManager = ComponentManager.getInstance()
def changeHistoryManager = componentManager.getChangeHistoryManager()
x = changeHistoryManager.getPreviousIssueKeys(issue.id)
if (x.join(' ') == "") {
   return null
return x.join(' ')
Make sure the settings for the field are:
Template: Free Text Field (unlimited text)
Configured searcher: Free Text Searcher
Add the field to the view screen for the issue if you want it to appear when you view the issue.
Add it to the Issue Navigator to have it display in search results.
Rathna
Hi Cyril,
Which version of JIRA does this code work?
Rathna
Matheus Fernandes
August 18, 2013
Sean,
It is possible to do that through the database running the following query:
SELECT 	ci.oldstring AS "Old Key", ci.newstring AS "New Key", cg.author, cg.created FROM changeitem ci
	JOIN changegroup cg ON ci.groupid = cg.id
	JOIN jiraissue ji ON cg.issueid = ji.id
	WHERE ci.field = 'Key' AND ji.pkey = '<issue-key>';
Just replace '<issue-key>' with the current Key of the issue.
I hope this helps! :)
RambanamP
August 18, 2013
movedIssues() in JQL Tricks Plugin function will do what you are expecting, check this
https://marketplace.atlassian.com/plugins/com.j-tricks.jql-plugin
