We need an automation if we have 2 customfields we need to update 2nd field based on 1st field value
thumuluru_shreya
Ex:
  • I have System dropdown field is there in that Occurrence, Value and Data are the 3 values present.
  • I have 2nd customfield named as result numeric field is present.
  1. if user selects `Occurence in result field it update as 1
  2. if user selects Value in result field it update as 2
  3. if user selects Data in result field it update as 3.
Based on system field dropdown values the result field should auto update.
For this I need single automation with the above conditions.
Can anyone help on this
Trudy Claspill
Hello @thumuluru_shreya
What is your experience with creating Automation Rules? Have you tried to create this one?
You could use the Field Value Changed
https://support.atlassian.com/cloud-automation/docs/jira-automation-triggers/#Field-value-changed
You would use the If/Else condition to evaluate the first field's value.
https://support.atlassian.com/cloud-automation/docs/jira-automation-conditions/#If-else-block
Then use the Edit action under each If/Else-if block to set the second field.
thumuluru_shreya
@Trudy Claspill , Could you please elaborate with my example?
Stephen.Lugton
@thumuluru_shreya
Have a look at the links @Trudy Claspill shared, they will show you how to set up the trigger and conditions for your automation.
For your example, if you follow those instructions with the following values you should gt the result you want:
When: Field Value Changed
Field to monitor: Dropdown field
Condition: IF or Else
IF Condition: Issue Fields Condition
Dropdown field = Occurrence
Then: Edit Issue
Results Field = 1
Else Condition: Issue Fields Condition
Dropdown field = Value
Then: Edit Issue
Results Field = 2
Dropdown field = Data
Then: Edit Issue
Results Field = 3
