I am a new project manager in a software company that has a few dozen clients that require monthly maintenance. Each is its own job with separate process taking anywhere from 20 minutes to an hour. They should have due dates, work estimates and priorities.
What is the best way to set up Jira for this type of work? I tried making one overall project called "Maintenance" and adding each client as a task, but this didn't seem right. I also tried making each client their own project.
Please let me know any suggestions.
Hello @jamie royce
Thank you for reaching out.
The best solution to achieve your need will depend if your clients must have interactions with the team directly on the issues (Help Desk) or if these interactions would be done by a different channel, so Jira would only be used for internal management with no client interactions.
If you need interactions between your team and the clients to be done and registered directly on the issues (Through a support portal or e-mail), I would suggest you to use the Jira Service desk application to achieve your need:
Jira Service Desk | IT HelpDesk
This app is billed based on the number of Agents (The members of your team that will be working on the issues) and provide an external customer portal together with an e-mail channel where your customers will be able to interact directly with the team responsible for their maintenance tasks, getting real-time notifications when any update is done.
Now, if you just need a system to manage the work done internally and no interactions with the customer should be done directly in Jira, you can use the Jira software application.
About these sentences:
Both Jira Service desk and Software application provide due dates, work estimates, and priorities. You can check these links to know how you can configure it.
Per your description, I understand you will have different workflow steps and time to accomplish each of the maintenance requests from your clients.
Based on the information you provided so far, that's how I would configure your Jira Application:
Let us know if you have any questions.
You are welcome @jamie royce
Let us know if you need further instructions about the suggestions provided.
