@Gustavo Gei I assume you are on Cloud since you are inquiring here. My cloud instance is not experiencing any issues but that means little in the Cloud world. I would recommend contacting Atlassian Support so they can investigate.
If you are on server then contact your system admin to look at the logs.
Thanks Jack. I think the previous post from Scott explains why some are experiencing the problem, some are not.
Hi @Gustavo Gei ,
It looks like there is an active incident for Jira Core with pages not refreshing. There is some info about hit here: https://jira-core.status.atlassian.com/
-Scott
