What is the Recommended way for Upgrade Jira Software 7.2.6 to 8.18.1
Deleted user August 11, 2021
I am Planning My Jira Instance From 7.2.6 to 8.18.1 , I need Compete documented Recommendations and Challenges Which I have to Lookup, Is It Possible to upgrade directly to 7.2.6 to 8.18.1.
Kandula Shankar August 12, 2021
It is the major Upgradation.
1. Need to check version compatibility and plug-in availability.
2. Need to take back for 7.2.6 including data, logos, plugins, Db config folders.
3. Download the 8.18.1 version
4. Start the installation while doing you should select upgradation for an existing.
5. Provide the Correct Path of existing version installation directory and Home Directory.
6. Start the installation.
7.  It will Take the back-up
     It will un-install the older version 7.2.6
     it will install the new version 8.18.1
     it will launch the Jira for new version
8. Need to check Weather all projects and other information Upgraded successfully or not
Pavel Junek
Hi @[deleted],
Welcome to Atlassian community!
If you want to be 100% sure that no problem will arise, ask about the possibility of a direct upgrade of Atlassian support and upgrade first in a test environment.
To prepare for the upgrade, please read the manuals:
Pavel
Thanq@VVSN SUDHEER VISSA
