What is the max # of issues my users can create in JIRA Server - Jira Software 8.8.1
Denise Cossa August 18, 2020
One of my users is worried about having more than 10K issues - is there a max number of issues that can be created per project? I don't think there is but they want a definitive answer.  Does having a 5 digit issue code impact performance or reports?  Thank you.
2 accepted
Datta Borude
Hi Denise,
Greetings for the day!
There is no limit to create issues in a project or instance.
There are multiple factors that may affect Jira's performance in your organization.  These factors fall into the following categories (in no particular order):
  • Data size
    • The number of issues, comments, and attachments.
    • The number of projects.
    • The number of Jira project attributes, such as custom fields, issue types, and schemes.
    • The number of users registered in Jira and groups.
    • The number of boards, and the number of issues on the board (when you're using Jira Software).
  • Usage patterns
    • The number of users concurrently using Jira.
    • The number of concurrent operations.
    • The volume of email notifications.
  • Configuration
    • The number of plugins (some of which may have their own memory requirements).
    • The number of workflow step executions (such as Transitions and Post Functions).
    • The number of jobs and scheduled services.
  • Deployment environment
    • Jira version used.
    • The server Jira runs on.
    • The database used and connectivity to the database.
    • The operating system, including its file system.
    • JVM configuration.
Please refer below link to know more about this.
https://confluence.atlassian.com/adminjiraserver/performance-and-scale-testing-965568707.html
Thank you,
Datta Borude
Thank you so much!
Like Datta Borude likes this
Daniel Vergetti September 29, 2020
does this applies even to the free version of jira software? i mean by the max number of issues/cards?
Datta Borude
Yes.
Like Daniel Vergetti likes this
Nic Brough -Adaptavist-
August 18, 2020
A high number itself, no.  The number is limited by the database, but to extremely lrge numbers.
I've seen a 95% functional Jira project with over a million issues in it.  The failing 5% were reports attempting to read too many issues at once.
SERVER
