I have a discussion with a friend, I read all the information and to me to create an issue collector you need
- Jira Admin or Project admin
and Create issue permission.
With just those two is enough. Correct?
Hello Marcela,
As you can check in the documentation below, the Administrators Global permission is required to perform any actions (Create, edit, access) regarding Issue collectors:
Hi @Petter Gonçalves ,
is that information still valid? The point 1 under the section `Edit issue collector` says:
"Log in to JIRA as a project administrator or a user with the JIRA Administrators global permission."
