I created a jira issue with assignee, however it assigns back to myself even though I put assignee name there. can you advise why it's happening? thanks
Hi SuJeong - Welcome to the Atlassian Community!
Are there Components in the issue?
Also, did you look at the History of the issue to see who/what might have assigned it to you?
Check under Project settings > Details. Then scroll down to the bottom and make sure you are not set as the default assignee.
thanks, I checked already but I'm not a default assignee, would it be something else keeps re-assign to myself?
