Hi @Ashwin,
Which tabs you have been clecked from the left side panel and then panel itself greys out.
Without knowing this we can not help you.
HI @Ashwin,
Greys out mean like as follows, if yes then it will happen for a few seconds and then you will be able to see all the tabs like normal.
I am also using Chrome browser only, it will greys out while page loading then it will come as usual.
The above image was taken in chrome only.
