When I log into jira project and click on the tabs on the left side panel, the panel greys out.
Ashwin May 29, 2018
I am using google chrome
Yogesh Mude
May 29, 2018
Hi @Ashwin,
Which tabs you have been clecked from the left side panel and then panel itself greys out.
Without knowing this we can not help you.
Ashwin May 29, 2018
Hi @Yogesh Mude,
The tabs like Backlog, Releases, Reports,Issues..
Yogesh Mude
May 29, 2018
HI @Ashwin,
Greys out mean like as follows, if yes then it will happen for a few seconds and then you will be able to see all the tabs like normal.
Ashwin May 29, 2018
In my case, its permanently faded and I am chrome and not using internet explorer where this is a common problem.
Yogesh Mude
May 29, 2018
I am also using Chrome browser only, it will greys out while page loading then it will come as usual.
The above image was taken in chrome only.
