When I search for overdue issues it returns issues not overdue
Rikard_Berg March 18, 2020
I have recently set up a small project with few issues. When I search for overdue issues it returns issues that are not overdue. What could be wrong?
I have reset all the timepicker format settings to default.
It returns 10 issues, where 1 is actually overdue and other 9 is due between 2 days to a month in the future
Jack Nolddor _Sweet Bananas_
Could you try this JQL instead?
due < now()
Regards
does not help
Could you elaborate more your response?
Do you mind to add some images to explain us where is the error?
Thanks!
I also noted when I sort on date, it's not correctly sorted. (the image is from the dashboard. I have changed the date format, but I have also tried the default with the same result)
It is a brand new install. I have hardly made any customization, basically used it out of the box. Just added a few issues and just wanted to search for overdue issues.
Sebastian Gastager
could you post the JQL?
due <= "0" ORDER BY due DESC
