For a few weeks now, we've been able to archive issues, but it's still quite manual... for us, the whole point would be to put issues that have been “Done” for 2, 3 or 4 weeks into archived form, so that they can be consulted afterwards.
Do you have a solution or has it not yet been developed?
@Jaquez Jeison It should be possible using this approach:
Here is an older tutorial that helps with it.
These are already available. Please let us know if you succeeded with it, as it may interest other community members.
Thank you for your help. Thanks to you, I was able to set up an automation that meets my needs. Much appreciated!
There is no solution on this.
And based on your requirement, I will say (in my opinion) this is no a best practice.
You can’t archive a subtask by itself, but you can archive its parent issue.
You can't search on the issues when archived, without unarchiving them.
You can't make a report based on the archived issues.
You can only view them from the project option "Archived Issues", unlesee you unarchive an issue.
Archiving should be used (my opinion) on old related information, such as:
Not just because an issue is older then, this might still be relevant based on the achieved functionality or else.
