Where to assign a permission scheme to a Jira Product Discovery project?
Dominik
When I try to establish a slack connection to my jira product discovery project, I get the following error message:
- I can not assign a Permission Scheme to my Jira Product Discovery project
- I have no slack User
Anybody were successful to set up slack integration?
App does not have write access to the project
 The Slack integration is missing permissions on this project
This usually happens because the project is associated with a custom Permission Scheme that is missing default Atlassian roles. Please, ask an administrator to perform the following corrective actions:
  • Edit the Permission Scheme granting all permissions to the Project Role atlassian-addons-project-access. Note this is required for all Atlassian integrations to function properly.
  • Other restrictions may still prevent the Slack integration from accessing the project. Please verify the integration's access, while in the Permission Scheme page, using the Permission helper button.
    • On the Permission helper dialog, select the system user named Slack, type in an issue key from the project, and select a permission such as View issues.
    • If the access check fails, edit the Permission Scheme granting all permissions directly to the Single user Slack.
3 votes
Robert Wen_Cprime_
You can think of projects in JPD as team-managed projects.  As such, company-managed Permission Schemes won't apply to them.
Yvonne Sutter December 16, 2024
I wonder why there are several JPD permissions listed within the permission scheme and yet we cannot add the scheme to a JPD project - what's the point of having those permissions in the scheme?
Tara_Westgate
January 9, 2025
THIS !!!!
Jamie Zeidler August 7, 2025
I was thinking the same thing
Grzegorz Charyszczak
July 5, 2024
I have the exact same issue. Did anyone manage to fix the problem? I found this article mentioning editing default permission scheme:
https://jira.atlassian.com/browse/JRACLOUD-76254
But as mentioned already, Jira Product Discovery is not using any permission schemes (since it is not company-managed), therefore this workaround doesn't fix the problem.
FREE
