Which of the test management addons work with next gen jira projects?
Deepanshu Natani
Out of all the test management add-ons available in marketplace like Zephyr, Xray, Test Rail, others, does any support the next gen projects in Jira Cloud?
3 accepted
Brian Walker
Hi Deepanshu,
Out of all test management tools, I like QMetry Test Management for Jira which has an end to end test management capabilities with Next-Gen project support.
Brian.
Reshma Padkil October 9, 2019
Hi @Deepanshu Natani
QMetry Test Management for jira supports Next-Gen projects. Here is the link to the app on marketplace.
https://marketplace.atlassian.com/apps/1215144/qmetry-test-management-for-jira?hosting=cloud&tab=overview
For further queries about QMetry you can always reach out QMetry support at https://qmetrysupport.atlassian.net/servicedesk/customer/portal/46 .
PVS
Banned
October 9, 2019
Deepanshu Natani
Thanks, I will check this out.
PVS
Banned
October 9, 2019
Hello
Currently, next-gen projects do not support Zephyr Test issue type. We have a feature request suggesting the implementation of this ability:
- https://jira.atlassian.com/browse/JRACLOUD-70685
"Xray " and Test Rail, don't support the new Next-Gen projects.
Also, I'd suggest the same as Jack, to contact the Zephyr support, they will be more accurate to provide you with more information about the plan to implement this feature.
PVS
Deepanshu Natani
I think Xray now supports Next gen projects.
Anyone in the community who can verify this?
José Domingues _Xray_
Hi Deepanshu,
Yes, Xray Cloud supports Next-Gen projects.
Here's a link that can help you with the setup: https://confluence.xpand-it.com/display/XRAYCLOUD/Project+Settings%3A+Next-Gen+Configuration
Best regards,
Team Xray
Like Deepanshu Natani likes this
Deepanshu Natani
@José Domingues _Xray_
Thanks for confirming.
