Check that you have move issues permissions in the from project and create issues permissions in the to project.
I have the permission of the create issues in the destination project.
The source project is a Next gen project.
There are no permission in it.
It sure seems like a permissions issue with the target project especially if you are able to move the issue to other projects. Might be interesting to create a test issue in the NG and try to move to a different project and the from there to the original destination project. I am able to move issues NG —> Classic fine.
Hi it worked after taking the create issues permissions.
Thanks a lot
Hi Kopal,
Have you the Create Issue Permission on the destination project?
See the Before you begin section under Moving an issue page for further information.
Make sure you have the Move Issues and Create Issues project permissions. Your Jira administrator can help assign any needed permissions. If you want to move multiple issues between projects at the same time, check out the Editing multiple issues at the same time page.
Regards
