While moving issues from one project to other project can we move users as well?
samba siva May 24, 2024
I like to move the issues from one project to other project along with users. Is it possible? If so how?
Hector Florin (Appfire)
Hi Samba,
Thank you for your question and welcome to the community.
You can achieve this and many more administrative tasks with our plugin, Power Scripts by Appfire.
With Power Scripts you can create an script that you can run to move your issues and then update the Project roles for the users related
You can use
userRoles and moveIssue routines for that.
And if you need some help to build your scripts, just open a support ticket and the team will be happy to help guide and provide some ideas to your scripts
I hope it helps.
Thank you
samba siva May 26, 2024
Thank you Hector Florin for your reply.
John Funk
Hi Samba - Welcome to the Atlassian Community!
No, that is not possible with out of the box Jira.
Like John Funk likes this
John Funk
You are welcome.
SERVER
