We have been utilizing the kanban board for months now, and today I cannot move issues between columns nor re-prioritize in same column by clicking and dragging. When I attempt to click and drag, nothing happens. I can change between different statuses by clicking the drop down menu in the issue card. This will move the issue to a different column, but I cannot click and drag. Please help.
Hey, @JT Curtis
The errors related to boards that have impacted your site today were caused by an instability in our CDN. Our front-end devs were able to apply the fix.
You should not see the problem affecting any user anymore.
Gabi
Hi @JT Curtis ,
After you change between different statuses by clicking the drop down menu , does the card switch directly to a different column?
Hello @JT Curtis
It's working fine on my end but I can see several posts reporting this issue on Community today. There's no incident reported on status.atlassian.com (yet), have you reached out to Atlassian support?
- Manon
