Why does JIRA look for carol.jar instead of carol-1.5.2.jar that comes with the install?
David Chang
April 6, 2017
I installed Atlassian-plguin-sdk 6.2.14. I created a skeleton plugin by using
atlas-create-jira-plugin
Then I ran in the directory with pom.xml
atlas-run
and I got a few exceptions such as this example:
[INFO] [talledLocalContainer] java.io.FileNotFoundException: E:\myplugin\target\container\tomcat8x\cargo-jira-home\common\lib\carol.jar (The system cannot find the file specified)
The interesting thing is that I am able to find carol-1.5.2.jar in the target location:
E:\myplugin\target\container\tomcat8x\cargo-jira-home\common\lib\carol-1.5.2.jar
So why does JIRA specifically look for carol.jar, not carol-1.5.2.jar that comes with the install? How to fix it?
I am new to JIRA. Any input is really appreciated.
Best.
Sam Hall
April 6, 2017
Hi David - Welcome to the community. Since your question is development related, you might want to try asking this over at: https://community.developer.atlassian.com as well (if you haven't already).
There are a lot of helpful and experienced people over there, so you will probably get a quicker response.
You can read more about the Developer Community in this article: https://community.atlassian.com/t5/Feedback-Forum-articles/The-Atlassian-Developer-Community/ba-p/459061
David Chang
April 6, 2017
Sam, thanks SO much for your info. I post the question in that place. You can delete my post here. Again, thanks!
Sam Hall
April 6, 2017
No problem David. No need to delete this one, really.
You might get still get an answer from someone.
Once you've posted the same question in the dev community, we can put a link to it here so that people can follow the trail.
Sam Hall
April 6, 2017
