I try to import a csv containing issues for a Project. These Issues should have an assignee and a reporter and i want to set those using a name and an Id. But when i try to do that Jira tries to create two users for that field instead of setting the fields to users that already exist in the system. I have deleted on of the newly created users and i have set one to inactive but when i reimport the csv they still get set as assignee and reporter.
how do i fix that?
Hi @JiraDeveloper and welcome to the community,
Can you post a screenshot of your mapping fields? Also, refer to this documentation for help https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
From the documentation:
Creating users
You can choose to have the importer automatically create Jira users for any values of the Assignee or Reporter field.
Users will be created as active accounts in Jira. Users will need to get their passwords emailed to them the first time they log into Jira.
Users with no real name will get the portion of their email address (login name) before the "@" character as their Full Name in Jira.
If you are using External User Management, the import process will not be able to create Jira users; instead, the importer will give you a list of any new users that need to be created. You will need to create the users in your external user repository before commencing the import.
If you have a user-limited license (e.g. personal license), and the number of required users is larger than the limit, then the import will be stopped. A page will be displayed showing a list of users that can't be created.
If Assignee and Reporter are not mapped, then no users are created.
Uncheck only the "map field value" checkboxes from assignee and reporter and try again. From my previous reply read the:
These are the mappings. I forgot about another detail by the way. There are other users that dont have a clone created by jira. i can add those to the fields without problems.
