Switching to jira after trello feels like a huge downgrade.
One of many stupid issues I faced is that it doesn't search inside the card - it can search for text only in title. Why is there even a search field if I can just use ctrl+F at the same page to look through titles? I need to be able to look for keywords inside the ticket too.
Top part of the image - empty search results for an ID
Bottom part - the same board with an open ticket that has this ID in text.
It's because Jira has a lot more power than Trello, with ranges of different (and differentiated, rather than just a blob of text) data, which has a downside that you have to be a bit more "clever" with the searches to cover all the places you might mean.
The quick search field applies a guess at what you might mean, and tries to be fast by focussing on the summaries as those are usually where the most useful human description is.
If a quick search doesn't find something, go to the standard or advanced search. In the advanced search "text ~ <something>" searches all text-like fields.
Thanks for replying.
https://confluence.atlassian.com/jiracoreserver073/quick-searching-861257204.html
From this it looks like the example with "~" will not work?
I tried looking for user IDs with "<ID#>" in quick search - didn't work.
Correct, ~ is a fuzzy search for text.
Sorry, I still don't get it... If I want to find in quick search just a number/word from ticket's contents, how should request look like?
Tried:
~ <369586>
~ 369586
~369586
text ~ <369586>
So even
text ~ "369586"
doesn't work in quick search... This is the line advanced search gives me. I guess quick search is there just for the looks then.
