I have an environment with 3 products:
All three environments are linked with Application Links. However, I'm now struggling to find any documentation on using Project Links between these products.
The only reasonably clear documentation is only explaining specifically what specific benefits I would gain from creating an Application Link between Bitbucket towards Jira (from Bitbucket's perspective).
However, I'm struggling to find anything about the other possible integrations:
So: What functionality is gained if I go through the trouble of adding project links on top of Application Links?
Hi Hans,
Great question!
Many core integration features between Jira, Bitbucket, and Confluence work with just Application Links. You can already view linked development info in Jira, embed filtered data in Confluence, and more.
Here's my take on Project Links and what extra benefits they bring:
Basically, Project Links can enhance the integration experience, but if Application Links are working for you, you might not need them.
Hope this helps!
Hi @Seon Shakespeare ,
Thanks for your reply!
So, it's still a black box of sorts 😂. I understand that it might help for some specific apps, but I gather that generally a project link in a native Atlassian environment doesn't seem to do that much. Other than the more concrete items for the Bitbucket integration.
