Hi everyone,
I've set up several custom fields with the wiki style render selected in the field configuration. However, while the renderer is visible on the create issue screen (I can see the same markup bar as in the description), none of the other screens are rendering the markup.
Any suggestions on how to fix this? I know that the field configuration (schema) are correctly applied since it works on the create issue screen.
Thanks for your help!
Hello Daniel,
Unfortunately, the behavior you mentioned is a bug in the new Issue view which was already reported to our development team:
- Wiki Style Renderer does not work for custom fields
That being said, I believe that Atlassian development team is currently working to fix it. Please, feel free to watch the reported bug to be aware of new updates.
Thanks for the info Petterson. Is there a timeline for the fix? Thanks! Daniel
Hello Daniel,
There is no date informed in the bug to fix it, however, the number of customers affected has increased the priority of the ticket, so I believe that it should not take too long.
Please, feel free to provide any comments on the ticket on how that bug is affecting you so our developers can have more feedback and better prioritize it.
You are welcome, Daniel!
Have a nice day.
Hi, we are experiencing the same issue and would like this issue to be solved. Is there any update?
Cheers
Unfortunately, our developers have not provided any updates about this bug yet, however, you can directly comment on the reported bug to verify if they already have anything about it:
Cheers.
My team is having the same question. I would like to know when this issue is gonna be resolved?
Wow, this was originally reported in 2018 and has still not been addressed? Same concern here.
We have this issue as well, and it's killing me having to answer all the questions about why the markdown isn't working. Please fix this. I'll by drinks, coffee or matinis for the team that fixes this!
