Without an add-on, need epics with their stories and other story data in a filter
Nick van der Net
Hello Community,
Without using an add-on, I would like to be able to product a filter on ALL Epics, with ALL their associated stories, and other story-based field data please.
For example,
We are an applications migration project. Our Applications are Epics, and the individual deployment and deployment types of the apps are stories.
I need to see a filter that for each Epic, I need their child stories and some associated data, so I can extract that to Excel.
Thanks guys!
Pramodh M
Hi @Nick van der Net
It is a bit difficult to get requirement done, but here is my solution,
First, find the Epic issues by running the following query
project = "projectKey" and issuetype = "Epic"
Now that you have got the Epics, find the issues linked to Epic by running the following query
project = "projectKey" AND "Epic Link" in (epicKey-1, epicKey-2, epicKey-3,...) OR project = "projectKey" and issuetype = Epic
epicKey-1, epicKey-2, epicKey-3... are the keys that resulted from 1st query
Pramodh
Nick van der Net
Hi Pramodh, that seems like a two-step process? And given we have about 70 Epics, quite a significant query. Might be better to develop the query externally and then copy/paste into Jira.
Is it possible to have "epiclink = all" or some such?
Pramodh M
You will get the Epics in CSV Format in the first result, which you can append in the second one.
There is no such way we can search like "epiclink = all"
Pramodh
