add Hierarchy levels in ADVANCED ROADMAPS in JIRA Data Center
Jenny Chen May 30, 2023
We have a few issue types: Epic, Story, sub-task,  Technical Requirement, Development Task, etc.
By default Hierarchy level is
  • Hierarchy: Epic to Story
  • Hierarchy: Epic to sub-task
Can I add
  • Hierarchy: Epic to Technical Requirement
  • Hierarchy: Epic to Development Task
Jenny
Aditya Verma
May 30, 2023
Hi @Jenny Chen ,
Since you already have Epic to Story hierarchy, you will automatically have "Epic to Technical Requirement" and "Epic to Development Task" if these are standard issue types.
If you add any standard issue type in hierarchy, it automatically adds all other standard issue types at same level.
Aditya
Hi Aditya,
If I selected Epic as top level, the options for Dev-task and Technical-req cannot be selected ( grey items). Below is the Hierarchy Configuration: I have added the first two rows as attached screenshot: Dev-task <-Development Task and Technical-req <-Technical Requirement. The last three rows were already present as default options. However, I do not have the ability to select 'Epic' when adding new Hierarchy levels. Do I miss anything?
Jenny
Aditya Verma
May 31, 2023
Hi @Jenny Chen ,
You can display hierarchy only from top to bottom levels. Since you have configured "Technical Requirement" and "Development Task" issue types to be above Epic level in your config, you will not be able to filter from Epics to Technical Requirements.
Level above Epics commonly get called things like Initiatives or Legends – though it’s entirely up to you. To add issue types above epics to your plan, you’ll first need to create a new issue type in Jira Software.
Aditya
Jenny Chen May 31, 2023
Hi Aditya,
Thanks for checking. I removed frist 2 rows, just keeped the original configration
I am unable to see any issuetype other than Epic, story , sub-task at bottom levels.
Jenny
Aditya Verma
May 31, 2023
Hi @Jenny Chen ,
Here "Story" represents all standard issue types (Bug, Task, Development Task etc.).
If you will create any standard issue type ticket under your epic KTX-1, it will appear on the roadmap here.
Aditya
SERVER
VERSION
9.4.5
