I try to create an issue, this message appears: "Component/s" field is required and the project "TEST" does not have any components.
When i try to add new component in components, there is no way to add.
What's the problem?
Dear Ali,
The message "Component/s field is required" is caused by your Field Configuration scheme. In the Field Configuration Scheme the field ''Component'' Is required.. yet you do not have the field Component on your screens, correct?
Depending on your team or organization's needs, you may want to make certain fields required to ensure that you're gathering the right information at the right time. Note that all required fields must be added to the Create Issue screen for associated projects and issue types, and that hidden fields cannot be marked as required.
Friendly Regards,
Jeremy Mooiman
Thanks. But why i can't define component for my project?
Dear Ali,
You need to Administer Projects permission to add a component.
Friendly Regards,
J
