add issue to component
Ufuk Fakioglu March 23, 2016
This question is in reference to Atlassian Documentation: Organizing work with components
Ask your question here...
3 votes
Michael Partyka
March 23, 2016
Hi Ufuk,
first of all you should add new components to your project
You should also add Component's field to the screen in this project
You are be able to use components.
If you will have any question please let me know.
Neslihan Anık
April 29, 2019
I added components to my project. When I open the components part, I can see the components I have created. however, when I open a component, it says 'there are no issues yet' I click on create issue, and issue creating page is opened. however, after creating an issue, that issues is shown under the project, not the component I want it to be in.
I use jira on web btw.
Thanks for your help in advance.
Melissa Cunningham
June 4, 2019
I'm having this same issue. Has a solution been created?
If we can't link issues to components...then what good is it to have a component? I might be misunderstanding the point of having components.
Wallace Mann September 4, 2019
Same issue, I think.
Once I have created a component, all newly created issues have the components drop-down, no problem.
But ... issues created BEFORE I created the first component, do not show the components drop down, and I can not figure out how to associate the old issue with it's component.
I love that Atlassian keeps adding more and more new features to handle obscure use cases.  I would love it even more if the basic, simple stuff was easy.
Like mahdi_hosseinali likes this
Jason Beguas
June 17, 2020
I also have this problem, can anyone help regarding this? Thanks
sean wilson
July 30, 2020
for those having issues with an issue created before the components you need to do the following:
Settings > issues > screens:
for the create issue screen AND Edit/View screen for your project: click configure.
then simply add the Component/s field.
you can now Edit those issues already created and assign to newly created issues.
Charles Robertson
I am trying to create a new issue for SourceTree, but I don’t know how to fill in the Component field. The drop down does not show me any values? Why does Atlassian have to create unnecessary complexity like this?
