archive project in jira
tanyaandrushchenko
June 5, 2019
I have tried to apply the method described here to archive a project online (applying an empty permission scheme). However, the project still appears in the project list of administrators, although they cannot access its issues. Is there a way to remove it from this list completely?
Jack Brickey
Yes that is indeed the case. It isn't a true "archive" where you would have to go to an archive section to unarchive it in order for it to appear. Admins will continue to see them which I agree is less than ideal.
Jack Brickey
you may wish to watch/vote for this issue - JRACLOUD-68228
Like tanyaandrushchenko likes this
tanyaandrushchenko
June 5, 2019
Then there is no way to remove the project from the list?
Teodora V _Fun Inc_
Hi, @tanyaandrushchenko
I can suggest you try Configuration Manager for Jira for this use case. You can easily archive old issues and keep the performance of your production instance intact.
You can see more about this use case here.
Jack Brickey
if on server/data center.
Teodora V _Fun Inc_
Oh... I'm helpful as usual :/
