automatically expand more than 5 comments in Jira?
Alex Few November 8, 2016
What  need to do for  automatically expand  more than 5 comments in issue in the Activity panel , for example 20 comments visible and another old comments should be hidden.
Alex Few November 10, 2016
Thank you for your answer!
I tried to put this option, but it doesn't work for me, because usually in a single task a lot of comments and after he collapsed the first 20 comments, still starts to show only 5 last comments . Maybe there is a property that would allow to customize the number of showing the latest of comments?
Vladislav
+1
Is it really possible?
rachelcarmena November 10, 2016
I think you have 2 options:
I hope be useful.
