https://10.0.9.202/api/Engineering/Analysis/Validate?Plant=EAES&Partnumber=1310468W001
hi,, im new to jira and i want to call above api with parameter Plant and Partnumber on transition using post function .
Basically what i want is when i click on tempvalidateRest transition ,Api should call and according to Plant and Partnumber values or status should update in other application ..
for this i hvae created webhook and call it on post function .. but the values are not updating ..plz help me with this
Hi @Sneha Gole
welcome to Atlassian Community!
Unfortunately, it is not possible to use your own variables (based on custom fields' values in issue) in webhook's url.
But I can image another approach could work for you.
Do you have Jira server or cloud?
If you have Jira server, I would recommend you to use ScriptRunner add-on and create post function with groovy script, which will take the values from the issue and use them to create url and body of the request.
hiiiii @Hana Kučerová I have remove custom fields ..now i have just create transition with none screen selected.
and i have set " https://10.0.9.84:443/API/Engineering/Analysis/Validate?Plant=EAES&PartNumber=E171476Y001001 " url in webhook ..
when i check the log file its show like below
does it means webhook is sent from myside correctly ?
No ..im guessing may be its because of network policy
The data in other application is not updated what should i do now?
Hi @Sneha Gole ,
did you try to check atlassian-jira.log?
If the remote systen doesn't "catch" the webhook POST, there should be record about it.
can you please tell me how to post json data in webhook?
hii @Hana Kučerová Can you please tell me how to post json data in webhook ? (i have API project on local machine and when i click on validate transition webhook gets call and get Plant and Partnumber in api project but not getting josn after i debug)
Hi @Sneha Gole,
please check Exclude body parameter in configuration of the webhook in Jira administration. The checkbox should by unchecked.
